- Joined
- 2 Oct 2007
- Messages
- 11
- Reaction score
- 0
- Country
I have a problem with my Baxi Solo WM50/4 powered flue wall mounted boiler.
The boiler was not firing properly but it has recently been serviced and cleaned and the gas valve has been replaced.
The boiler now ignites properly and stays alight but it takes a long time (90 minutes!) to heat the radiators even when the valve to the hot water cylinder is closed.
All of the obvious things have ben tried, the radiators have all been bled and there appears to be no air locks in the system. All of the radiators are hot but you can easily hold your hand on them even when the boiler is at the highest setting.
It is a simple system with one loop and there are no room thermostats involved.
My plumber is baffled at this stage.
I would appreciate any help that anyone could give me.
