Hello, i'm experiancing some worring problems with my boiler. The first problem is when its trying to ignite the pilot light, instead of the whoosh and ignition as you would expect its seems to whoosh click,whoosh click, whoosh click and then start up after a minite or so (apologies for the description, cant think how else to describe it!). Then once ignited it will at fairly regular intervals start to re ignite the pilot light with the same whoosh click whoosh click( here i go again!) even though it was already alight! And it will constantly do this until the timer or myself turns it off. The other worry is the timer its self, often ill get up in the morning to find the heating still on yet the timer was set to stop it at 10:00pm, if i turn the timer around by twelve hours this seems to cure it for a week or so then it does it again, annoying and no doubt exspensive. And lastly the thermostat! quite often the boiler will shut off as if it has done a good job and reached the room temperature its been asked to by the theremostat yet quite clearly im freezing my bits off. So why does it think its done its job? Does this sound like a good service is required, its been about 2 yrs since the last one. Any advise would be much appreciated
