can anyone offer advise ,i have a baxi solo 40/4 rs pilot is alight but boiler not firing, thermostat seems ok and overheat not tripped, any suggestions?.
Big Red, I can see that you have received the standartd level of help, advice and sarcasm from some contributors. The problem is that the rules of the forum, forbid the offering of "gas advice". They don't say you must attack and belittle at every given oppportunity.
I won't go into boiler stuff, but if you have 240V across the terminals on the gas valve, when heat or HW demanded, you defo need an RGI. If you don't, it MIGHT be able to find a faulty external to boiler. BUT, the fact that you have asked suggersts that you are not competant to trace and repair an external fault.
