- Joined
- 3 Nov 2004
- Messages
- 18
- Reaction score
- 0
- Country
My boilers runs for a while and then safety button pops out (the one on the left side of the termostat). When I set termostat to LOW it works fine, only when it's set between 1-max this things happen. I've also noticed that boiler is getting very hot quite quickly and today the flame changed from blue to slightly red.
The plumber on the phone said it might be heat exchanger. The pump is set to 3 (which is max), so I can't increase the flow.
We had this problem before but someone did something with a pressure switch and then it was fine for about a day, that's why I'm not sure if it's a heat exchanger, because it wouldn't work even then I believe.
This topic is continuation from this one //www.diynot.com/forums/viewtopic.php?t=41597
