Hello again group.
I have a question regarding a Baxi Wentworth classic gas fire, its quite old, I believe 8-10 years. The fire doesn't give out much heat, certainly not enough to heat my living room which is approx 20x15 x 10 feet high. The fire was left in by the previous tenant and when I went to purchase a new fire from my local showroom the salesman told me that the Wentworth should never have been fitted to my old fireplace, and that it had been modified to fit (side flanges cut down) he also told me that it would be very difficult to get a replacement gas fire to fit as it was under the standard opening width, I measured the outer flanges on the fire and it was 420mm. When I questioned him regarding the poor heat he told me that a flue baffle should be fitted to restrict the draw from the chimney, is this correct? The property is three story's high and there is a lot of draw on the fire, when I looked up the flue I can see 4 circular panels have been knocked out of the fire top, should only a couple have been knocked out to restrict the air flow?
Regards
Otto
Regards
Otto
