Hi, My son's flat has a Baxi 38/3RS gas boiler for CH & HW. The CH is not working (rads not heating) I'm also not sure how well the HW is working either. Anyway, the pilot is lit OK and flames up when stat is turned up but the flame dies back to the pilot after a minute or two. While boiler is switched on there is a pump located inside and above the boiler which has a loud squealing noise coming from it. Is it likely to be the pump that's causing the CH not to work? What is involved in replacing the pump and could I do it? I'm an ex- spark not a plumber.
The info on the pump is: Grundfos type UPS 15-60 130.
Any advice will be greatly appreciated.
Steve
Steve
