Hi my fan went on my baxi boiler wm 70/4 so it would not ignite the gas as the fan was broke, so I took the fan out and had a look and as I manually turned the fan myself I noticed a little bit of resistance in turning so I gave the bearings a good blow out or clean then sprayed with WD 40 into the bearings to loosen them up and WOOHOO it worked connected the fan back up now the fan fires up and ignites the gas. But I want to know is how to do a service on the baxi boiler myself as in cleaning the inside of any soot or debris, can't find anything on web is it just a case of taking the front offf the boiler and giving it a good clean.
Any help apprieated thanks
