- Joined
- 28 Dec 2017
- Messages
- 2
- Reaction score
- 0
- Country
Hi... I have a Baxi WM/70/4PF but have a problem with the pressure switch,
The switch keeps filling up with water,, I'm not sure how or why its doing this,, I have the switch loose so every once and a while I disconnect the tubes and let the water out. not ideal but it works.
I have sealed the two metal pipes where they drop out on the rear chamber/void that the flexi pipes fit onto, the pipes are also new, I have a new switch here and will fit once I find a solution to stop the water issue, is this moisture buildup in the chamber and gets into the pipes and then finds its way into the switch ( lowest point on the vacuum pipes ) any help is greatly appreciated.
Regards
Nick
Regards
Nick
