- Joined
- 28 Sep 2017
- Messages
- 4
- Reaction score
- 0
- Country
I wonder if someone could help me.
I have a Baxi WM50/4 RS SS based CH system. The boiler has started to ignite when the controller is switched off and the pump is off. Initially I thought it must be a faulty controller, and changed the controller. Unfortunately the same thing happened again.
In the last few years I have had to replace the pump, 3 way valve, tank, controller and most of the wiring. The only original parts of the system are the boiler, pipework, tank thermostat and room thermostat and the thermostat leads. The system worked properly for 3 years since the last work I had to do to it.
At the moment, when the system is working, the hot water comes out excessively hot.
I have the entire system on an electrical isolation switch. The boiler works properly for 18-24 hrs after switching on, then it starts to fire up regularly when the controller is switched off. We then isolate the electrical system (no power to boiler, controller, pump etc), and find 24 hrs later that the boiler over heat switch has activated & the pilot light has switched off. This implies to me that the boiler has fired up even with the power off.
I wonder if anyone could suggest possible faults so I can look at areas that might have failed. Due to the age of the boiler, I am concerned that if any parts in the boiler have failed, then I may not be able to get spares.
Regards,
Richard.
Regards,
Richard.
