Hi, I have a baxi combi 105e, I had a small leak at the the end of the pin and after reading some post I decide to replace the diaphragm, washer, o-ring and nut which come with the repair kit.
Followed all instructions, turn on cold water valve and leak fixed. Then Turned on power. However it will now not fire up the green neon on switch is lit. I tryed to reset R it but no joy. None of the fault lights are lit only the green on light.
However After 10 min tried to reset again this time it fired up, yippee. But this morning the heating did not come on via the usual timer and no hot water. Only the on green light is lit. Tryed to reset again but nothing happened.
Before I call a plumber any ideas?
