- Joined
- 17 Feb 2006
- Messages
- 375
- Reaction score
- 2
- Country
We had 2 bow windows replaced - front room and bedroom, one above the other. Our house is a semi, the other half has the original windows.
We kept the design the same. 6 vertical sections, divided by a transom rail about 400 mm down.
I'm getting other windows around the house replaced so looked at fire regs - means of escape.
I've just looked at the opener. The actual hole is only 330mm x 740mm so nowhere near regs, never mind the obstruction caused by the actual opening light. This is a side hung one. Plus it's only 750 mm off the floor.
But to have had any chance of getting near regs it would have had to be 5, maybe even 4 vertical sections, and probably major building work to get the curve of the brickwork underneath to match. Plus plug ugly.
Have we broken any laws? Do I need to worry about anything? This window would only be a means of escape if we were trapped in the room, as it's the highest window and there are others that open onto flat roofs. It's an ordinary family property, no house in multiple occupation or anything.
Thanks.
Thanks.
