Hi there!
I have a 1920s bay window with sloping roof atached to my lounge.
The original lath & plaster ceiling in the bay (1m deep x 2m wide) deteriorated so I removed it. Since there was no insulation fitted I would like to insulate the bay ceiling as efficiently as is sensibly practicable before replastering.
My idea was to put 50mm Celotex friction fitted between the 50mm ceiling joists which are 300-400mm centres. And because I will not be able to access the roof space once the plasterboard is up I thought I would put ordinary 150mm insulation wool across and over the joists first. The slated roof is underfelted by the way.
So my questions are:
1. First, is Celotex a reasonable idea to put between the joists?
2. Ditto the idea of putting ordinary insulation across and over the joists too?
3. Would the additional insulation over the joists create a potential moisture problem for the timbers?
4. When considering the previous question would it make sense to add a vapour barrier underneath e.g., foil-backed plasterboard?
5. Celotex advise a 50mm air gap above the board. Obviously in my case there is plenty of air space above it before it meets the roof, but does this indicate a need for 50mm clearance on the actual joist timber, i.e., should not have Celotex full height of joists?
6. The Celotex board in Wickes (because it is sold in small sections) does not indicate which type it is. Is it all the same or should I specify a particular type at, say Travis Perkins?
7. I have read bits 'n pcs about timber acting as cold bridges. Would this presumably be negligible for such a small roof?
7. Would 12.5mm over 9.5mm plasterboard be recommended for additional insulation?
I can post a pic of the exposed interior of the roof if it helps anyone.
Thanks and regards,
Thanks and regards,
