Bay Window Tiling
13 Sep 2008
Leeds
I currently have a Bay at the front of the house which extends from the ground floor to the roof line. Currently the area between the upstairs and downstairs bay windows is finished with a rough cement / tyrolean coating. I am looking to get this area Tiled. Can anyone advise with regards to potential options / suppliers of the tiles?
Apologies in advance for the lack of detail and rather poor explanation.
Thanks.
The only possible issue I can see is how much the upstairs cill overhangs the render and likewise any lead flashing that may or may not be fitted at the moment.. everything else should be easy enough..
Can you advise where I would source the appropriate tiles from? I am struggling to locate suppliers of the tiles specifically the tiles that finish the the angles of the bay window.
Thanks.
Usually we would close mitre the angle details, take your time and it'll look good.
However, what area are you from? I'll try and point you towards a supplier..
PS, not much point going to a Builders Merchants.. Some of the big boys wont know what your talking about and if they do will try and shaft you on cost. Stick to specialist roofing merchants.
