bbq to gas supply
4 Oct 2011
Wolverhampton
Hi All,
I have a question, i'm thinking of getting a gas line extended from the kitchen to an outside shelter, From there having a bayonet fitting of some sort going to a bbq. That way i don't need to bother with having to keep buying/refilling gas bottles.
Can this be done and can you buy a connector that goes from a bayonet to a jubilee type to a bbq?
You will need a Natural Gas BBQ if you want to run it from the metered gas supply. Check gas safe register for local engineers with “Leisure” appliances on their ticket. They will be able to advise further.
if you were buying/refilling gas bottles your BBQ would be LPG and wouldnt work on the supply to your house unless that is also LPG , you get leisure gas points that the BBQ would just plug into with a bayonet fitting, but if you are on mains gas and you want to do this as already advised you will need a natural gas BBQ and they can be very expensive, I had an LPG one and binned it, the whole point of having a BBQ is the flavour from the coals or bark used to do the cooking, gas doesnt do anything except supply the heat
