Is it possible install beam and block flooring on the 1st floor of an existing old house (build circa 1930's)?. Current house is going through a complete renovation, and we are looking into the posisbility of doing this. The idea is to create a floor with minimal bounce, and be able to lay wet ufh in a concrete screed (over the beam and block floor). The house is detached,has cavity walls and is of standard brick construction.
All the guides i've seen concentrate on ground floor installation - maybe retrofit to upper floors isn't possible because the b+b load bearing walls aren't cost effective or practical to take up to the first floor?
Has anyone done this before on an existing property?
