I am making a lean-to carport, with a ledger against the house wall, and posts supporting a beam on the other side.
It will be 2400 wide, topped with 10mm twin-wall polyacarb, with rafters in 70mmx32mm at 600mm centres. I will probably use galvanised joist hangers as I am not good at joinery.
It is going to be 6metres long, and I have had difficulty finding timbers that length at modest price.
My local cheap timber yard has decking long enough, the timbers are 145x35 finished, and I am thinking of using one of them, or if necessary two, for the beam on the posts, as well as for the ledger. They are pressure-treated which I think is useful.
To allow room for car doors to open, I would like to have a span of 3metres (or preferably more) in the middle of the shelter, with two posts at each end 1200 intervals or therabouts.
Would this beam be adequate for a 3m unsupported span? I could if necessary put "gallows" braces from the posts to the beam at about 1m from the posts.
