Hi all
I've recently moved into a late 1950s house and just been adding insulation to the loft.
I used a couple of loft boards between joists as much as I could but did also just stand on the joists at times.
A crack has now either appeared or got worse in the bedroom. Having only just moved into the house I can't remember if it was there before or not. However, there are signs of fallen paint on the bedroom floor under the crack.
The crack runs the opposite direction to the ceiling joists which is odd?
Although, in the loft are 2 or 3 joists on top of the 'main' joists going the opposite direction. I also stood on these.
Should I be worried that the loft structure or joists are damaged? or can I just repair the crack and forget it?
At some point I was to also add more joists on top of the existing joists and board on top of these so the boards so I don't squash the insulation down when boarding. When done the loft will be for storage only. I'm concerned about doing this and going in the loft again now though!
Thanks for any advice
