Hey everyone,
I have a room in my new house which is 3.7m by 3.3m which currently has nothing in it. This is going to be our bedroom. The floorboards underneath are, on the whole, in good condition, they look like someone had used them as their floor before the previous occupants added carpet - they had been lightly treated.
Here's my plan, the carpet and underlay have already been removed (because they were grotty and smelly).
Preparing the floor...
1. Remove gripper rods.
2. Remove any staples
3. Use a center punch to hammer down any proud nails
4. Exchange any boards if necessary
5. Fill any holes if necessary... gripper holes I intended to fill with PVA and sawdust. Some knot holes I thought I'd fill with an expoxy and sawdust mix.
Sorting the gaps
1. PVA and then hammer in the slivers into the gaps.
2. When dry use a plane to take off the excess.
Sanding
1. Hire a stand up sander, sand the floor. - The floor isn't too bad so I'm guessing nothing too coarse. Do I get different belts to get a silky finish before I treat?
At this stage I would wear a mask and would tape up the door to minimize dust elsewhere in the house.
Treating
1. Treat with something - I need some advise with this part.
Done!
Is that essentially the steps, have I missed or over simplified anything?
For a first time, how long would someone expect this to take for a room of this size? - Grippers around the perimiter, I guess removing say 20-30 staples perhaps. Filling half a dozen holes, exchanging a couple of boards.
This is the first time I've attempted something like this. Am I correct in thinking this should be within the capabilities of a novice DIYer? - I've removed gripper rods before a few times, handled an orbital sander, lifted floorboards, used a plane, used epoxy. It seems to be the combo of these things...!
Any help, guides, advice very much appreciated.
Thanks.
Sorting the gaps
Sanding
Treating
Done!
Thanks.
