Hi all,
Firstly, I'd like to thank you all for the lots of tips/help I've gleaned from this site in the past. Though I've only joined just now, and this is my first post I've used this site as a primary source of research before embarking on many previous DIY jobs.
We've just bought a house, built ~50s. The bathroom is very small and we've decided to move the bathroom into one of the bedrooms - and convert the existing bathroom into a small box-bedroom.
I have a thousand questions to ask but for now I have a few to get you started! Apologies if they're dumb or have already been answered elsewhere. I've been researching online for a while now and to be honest I have found conflicting answers on some sites.
I'm an enthusiastic DIYer but a DIYer all the same. I would like to know firstly how much I can do myself and how much I will need to get a professional to certify or get building regs involved in. Underfloor heating looks to require an electrician. Not sure if the plumbing aspect is as stringent.
1) The existing soil stack is cast iron and with it being in a position to service the current bathroom rather than the bedroom we'd like to convert I was considering adding another, plastic, soil pipe to a better location - then removing the old CI later. I think the main sewage drain runs parallel with the back of the house so I think it's possible albeit a big effort. I believe I can get sufficient fall to tee into the existing soil stack but the span would make it look a little unsightly as well as any complications in connecting to a CI pipe. Does this sound sensible, and if so will I need Building Regs. involved to do this? The building is not listed.
2) For the new bathroom I intend to use plastic speedfit pipe in most places and copper only where needed for tails to taps/shower and towel rail (will be going from plastic on existing CH system). I know there is some debate on the use of speedfit over copper/solder but I have weighed things up and decided plastic is better for my circumstances. My question here is more on the bonding of the pipe work. Will it be required and if so to what extent? - I have read about bridging over speedfit till you get to copper but that could be a couple of metres for each tail for what I'm planning.
3) Final question: We're hoping to raise half of the floor in the new bathroom and use it as a wet area with a tub on one side and a walk-in tiled shower on the other. I have been pricing up various wet room trays and have one question which I can't find an answer to. Is the wet room tray only necessary to create a gradient? If so is there anything stopping one constructing a tray out of plywood with necessary gradients and drainage? My uncle is a retired patternmaker and I'm not sure if there is anything he couldn't make out of timber! From what I've read the membrane or tanking paint acts as the water barrier so I'm not sure if the material of the sub-floor is important.
Thanks for any responses and sorry I have padded it out! I can see me using this site a lot for my questions over the coming months so any tips of how to ask the right question/where to post will also be gratefully received.
Simon
Simon
