A long time user of this forum for help and advise, but now have a question..
I need help with a wiring diagram for two bed side lights, thinking this will need relays.
To explain:
Bedside lights either side of the bed (side A and side B), both have a light switch below.
Switch A operates Light A (on/off)
Switch B operates Light B (on/off)
I also want a master switch on entry to the room, to turn both lights on or off (2 way)
Switch M operates Light A&B (on/off)
If Switch A is on, and Switch B if off, them Switch M can either switch both on or both off. Allowing later independent use of Switches A or B. (This is what I’m after, hope it makes sense!)
I know in a standard two way circuit Switch M would alternate between A&B , not providing the correct control.
I’m sure others may have this setup but I’ve been unable to find an example online.
Help
To explain:
Help
