I have a really stupid/simple beginner question, I looked in the FAQ but could not see anything that answers my question.. So apologies in advance if this is answered elsewhere.
I have just replaced the 2 valves on a radiator. One valve is adjustable +/- (not a TRV) the other is the "lockshield". I replaced the old +/- valve with a new one and the old lockshield valve with a new one.
Q1) Is there any difference between these valves. Internally they looked exactly the same, only difference is one has a screw-down cap the other is adjustable. NB they are pegglers.
Q2) I assume that the pipe/valve to get the first when the CH is on (radiator was disconnected and valves turned off, when i did the test) is the "input/" flow ! Is this a correct assumption?
Q3) I am confused because it is my lockshield valve that gets hot first, does this mean I have the +/- valve on the "return/output" flow, is it the wrong way around?
Q4) If i install a TRV on the radiator, does it have to be fitted on the "input" not the "return", if it is a bi-directional one - does it matter??
Thanks for any help
Steve
Thanks for any help
Steve
