Hi All,
I’ve just moved into a new house and am going to attempt decorating (completely new at this so please bear with me!!) wanted a bit of advice on wallpaper/painting…
Every room (excl Bathroom & kitchen) is covered in a horrible, thick textured wallpaper that has been painted and painted over. From the looks of it, it’s been up for a long time. I can feel bumps under some parts of the walls, and am worried what I am going to find when removing the paper. I want completely plain smooth walls to paint onto.
I am going to start removing the wallpaper in one of the rooms this weekend with a scorer and steamer. I wanted to know: in what state should the walls be before I consider getting them re-plastered? I would obviously rather not have them re-plastered, but am worried as it is an old house and the wallpaper looks so thick and old that they might be in need of re-plastering if I wanted a smooth finish.
Once I have removed the wallpaper should I clean the walls with sugarsoap and water?
If the walls are just a bit bumpy and uneven, could I just sand them down and then either paint straight on to them, or would you recommend lining paper (I want very plain, smooth paper if this is the case) and is that hard to put up?
Thanks!!
Thanks!!
