BEKO BA51NE PROBLEM WITH GAS DISTRIBUTION WITHIN THE COOKER
29 Mar 2012
HI MY MUM TOOK DELIVERY OF THIS COOKER ON MONDAY.WE GOT A GAS SAFE FITTER IN TO CONNECT TO THE MAIN GAS SUPPLY,PUTTING A NEW HOSE ON AND EVERYTHING HAS BEEN CONNECTED UP CORRECTLY.WE BURNT OF THE FACTORY RESIDUE ETC,BUT EVEN THOUGH THE SUPPLY FROM THE METER IS CORRECT THE COOKER IS NOT DISTRIBUTING THE SUPPLY EVENLY THROUGHOUT IE IF THE GRILL IS ON IN ISOLATION ITS FINE BUT IF WE START TO USE OTHER PARTS THAT IS GAS RINGS THEN THE GRILL WILL COUGH AND SPLUTTER AND EVENTUALLY GO OUT,IT SEEMS TO ME THAT IT IS ROBBING PETER TO PAY PAUL.THE FITTER DID A GAS RATE WITH EVERYTHING TURN ON AND THE COOKER WAS ONLY ASKING FOR 8 WHEN IT SHOULD HAVE BEEN 12,ANY HELP WOULD BE GRATEFULLY APPRECIATED.THANKS
Wont be the cooker at fault is the gas hose bayonet on correctly if so you need to check the gas supply it can only be one or the other
