Currently stumped after looking to diagnose a fault with my friends condensing tumble dryer.
The dryer isn't heating so I checked the thermal cut out (one with the red stalk) and it is not tripped. Pulling the stalk up (simulating a trip) stops continuity through it.
The other stat appears to be one shot type where it won't reset if it trips. On testing iy I'm getting about 400 ohms which I'm assuming means that it's ok.
I know it's not recommended but I carried out a live test and only got about 1 volt to each of the stats with the machine running which I'm guessing isn't normal.
Is there anything else I should check apart from the elements themselves?
Cheers,
J
Cheers,
J
