I can anyone help me I have a beko dishwasher and today has stop washing with hot water and does not dry can anyone suggest anything to try or replace I have tested the heating element and seems to be working with a Mulitmeter hhhhhheeeeellllppppp lol
There are cut outs on the heater have you checked these as well if so then you need to check the wiring from the pcb to the heater if thats ok then it has to be the heater relay on the board but check also for dry solder joints to the relay on the pcb
