Hi Guys,
I am hoping to get some help regarding my broken Beko dishwasher.
My dishwasher has been running fine for about 6 years and it has stopped working recently, it's droning once I chose a program and closed the door, after a while the humming noise stopped and then it started again to try to fill water I guess.
I pulled it out and opened it, did the 45 degree trick as suggested in this forum which didn't help, then I purchased a new water inlet valve and replaced the old one, which appeared working initially, if I chose program 3 (58 minutes), it could take in water and run down to 43 minutes (so running for 15 minutes), and then stuck, when I opened the door, it's very hot inside, so water heating should be working fine. After a few days though, it has gone back to the same old issue again, just humming, not able to start a cycle at all.
It drains fine, as when I pour in a jar of water manually, it'll get drained away first before starting a cycle.
I thought it could be the valve I purchased from Amazon is faulty, so I bought another one from a different Amazon vendor, replaced it, same thing again.
One thing I noticed is that there are full of water in the salt reservoir, is that expected? I haven't re-fill the salt since purchased the dish washer as I thought the 3-in-1 finish tablet should do the same thing.
What could be the issue here, is it possible that I tripped something over when replacing the valve? Any help or advice will be appreciated, thanks.
