Our Beko DW663 top rack is not cleaning properly as the top arm does not always spin.
I've cleaned all the filters at the bottom of the dishwasher, cleaned the arm, checked the pipes going to the top rack for blockages and ensured the top rack connecter to the top pipes securely.
I've also checked there is no kink in the connection hose and drain hose.
We've recently had a water softener installed. The dishwasher issue did not start straight away after this was installed but happened soon after.
The pressure is still really good, for example we have a combi boiler and this is still working fine, but I was wondering if the water softener may be the issue. I can't see why it would as the dishwasher fills then the pump kicks in.
Does anyone have any suggestions what to try next? Could it be a pump issue? Or maybe the dishwasher does not fill up quicker enough as there is a timed fill process?
Adam
Adam
