Our Beko dishwasher DWD5411 swithches on, pump runnning but does not fill up with water. I tilted it few times and it worked but it now does not fill up with water at all. There was some stain on the tray where the float switch sits, which I cleaned up. I thought it was an issue with the inlet valve. I tried to replace the inlet valve and noticed new water on the tray. There are two small bore clear pipes attached to the float switch, one from each side. I switched on the machine and noticed a bit of water actually coming out of the float switch through one of these pipes. I am guessing this is what tripping the fgloat switch and stopping the inlet valve to let water in to prevent flooding.
Can anyone help me to understand why this is happening and what needs fixing please?
Thank you.
Thank you.
