Beko Fridge Freezer defrost
15 Dec 2007
Suffolk
F.A.o Nestor-Kelebay or anyone else that can assist....
I read Nestor's detailed report on the fridge freezer and it proved it extremely useful. I have a fridge freezer, which is frost free, but is not defrosting and I have had to do manually.
I have checked the defrost timer and it is working. I have turned the shaft and it does cut the compressor out and back in. I have left the fridge running and it also automatically does it itself. Good.
However, I have the back panel off from the freezer compartment and the heaters do not appear to be working on the evap.
How do I discover if it is the heaters or the actual defrost thermostat ? Is there any easy way to test ?
I would appreciate all useful testing procedures, as I have finally been able to remove the back panel and eventually get to the coil / heaters and stat !! What a nightmare, glad to see that Beko thought about the service and maintenance aspect !! Well done them.... so if anyone can help as I have gone so far, I would be very glad...
Look forward to any assistance....
Cheers
Blanchie
