BEKO W/MACHINE BELT
30 Jun 2006
Kent
I have just purchased a beko washing machine 1600 spinmodel no.WMA 765 S PURCASED FROM EBAY AS A GRADED MACHINE ARRIVED WITH NO TRANSIT BOLTS,WORKED FOR COUPLE OF DAYS THEN WOULD NOT SPIN,TOOK OFF BACK,BELT HAS COME OFF,HOW DO I PUT IT BACK ON,CANT SEE TENSIONER,DOES IT HAVE ONE.HELP!!!!!!
dont no about your washing machine but some dont have a tensioner, those type the belt stretches onto the pullys, have a look at how the motor is attached and see if it slides,if not put belt on the motor pully then feed it round other pully watch your fingers...
Your machine has a stretch belt.
Put it around the motor pulley and cable tie it to the drum pulley. Rotate the drum from the inside of the machine and it should go on with no problems.
SLEEPYHEAD FANTASTIC TIP,BELT WENT ON A TREAT,SAVED THE COST OF AN ENGINEER.CHEERS MATE
