Beko washer wm5120s wont wash or drain
8 Sep 2006
Hi guys got a Beko WM5120s washer where the power on/off swich had gone so replaced that no problem, and the plastic rocker on the light/button assembley, so swapped that no problem.
However usaly we put power on, turn dial to cotton 40 deg and press start but now it wont do anything. iv tried to put it on test, 90deg hold start and power on, that wont do much. sometimes when set to a wash it allows about 1/2 inches of water in drum and then stops, if we restart washer same happens again.
The only lights we get are the "wash" light and the start button light wich somtimes flashes. looked at filter and that clean and pump if flicking round in stages like supposed to on this washer. So any help is welcome. Thanks.
