Anyone got any tips on replacement of the drum bearings on our BEKO Eco Care washing mashine. I've done similar jobs on other machines but would welcome advice on this model
Depends on the model and year of manufacture the very early BEKO's had a tub front which clipped off and you could knock the bearings out the tub but they would be very old now and really not worth the effort. Now some models have a sealed tub which means you have to replace the tub assy complete and some have a split tub in which you would replace the rear tub half complete . post model details
On that model the outer tub splits apart you would need to replace the tub rear tub seal and possibly the inner drum if the shaft has signs of damage . the tub rear which contains the bearing is around £95 on its own
