Hi there,
I have a Beko WMA510W washing machine which has started making an awful noise on full spin. It whines a fair bit on a normal rotation but it is now unbearable and appears to be making the water pipes all around the house clang!!!!
I've cleaned the filter, checked the balance blocks and springs and removed the belt to check the bearing in the drum. All are fine.
The noise is coming from the motor and when I take the brushes out is disappears. They are both quite worn and have around 15mm left but could they really cause this noise?
It almost sounds like there is air in the pipes and it only occurs on the fastest spin?
Any help would be greatly appreciated
