BEKO Washing Machine resets back to End without washing
4 Jan 2014
Surrey
My BEKO WMB81241 washing machine was working fine until the belt started to fray and managed to cut the wires to the Thermostat Temperature sensor. I re-soldered the two green wires back onto the connector (no polarity indicated so presume wires can go either way! tried both ways anyway...) but now all i can get the machine to do is Rinse! I have tried resetting, running a self-test and even leaving the machine OFF for 24hrs but none of this has worked. I replaced the thermostat but this has not helped either! i have drained the machine completely and still no joy. If i unplug the sensor the machine works fine, but the wash is cold. if i replace the with a hot fill, it also works fine! but again without the temperature sensor plugged in! any help would be appreciated, before i lose my rag with this BEKO crap machine...
