beko washingmachine's soap drawer is blocked?
16 Aug 2005
London
my machine's problem is after I set the programme and switch on the machine, the washing powder can't be flush down, the water just came out, flow down to the floor and I have to switch off the machine. I have checked the powder drawer and some water are still there, that means the pipe has been blocked, and I used a wire to do something but in vain, what's happened?
p.s. my washing machine is beko WMA 10w
Once you have cleared the blockage it may be best to change to washing liquid or put the powder in a ball directly into the drum. If you take the lid off the machine you may be able to reach the hose from the drawer to the drum. usually if you squeeze this hose you can force the soapy gunge out into the drum.
how to take the lid off, and i can't clear the blockage, how to do it, the water is still there, thanks
I can't remember offhand how Beko lids are fitted but on most machines you take out screws along the back edge of the lid, slide the lid forward or back and lift it off
