Beko WMA 1512 W
27 Nov 2006
Surrey
my Beko WMA 1512 w has a fault
when you switch on the dial rotates from number 1 to number 5
then water enters the machine, it washes for a bit , i didn't feel any heat in the bowl but not sure if it would anyway
is this the pcb or the program switch or both
is there any way of testing
thanks in advance
i have investigated this problem further
on dial number 10 ( woolens wash) the machine does a wash but i can't feel any heat .
I have read that this problem can be caused by problems with the heating element or motor
i have changed the element but not thermostat(could the dial running on be caused by this has failed)
could it be the brushes in the motor
