Can anyone help please the prewash light keeps flashing on the above washing machine. can anyone assist me with this problem? I have turned it off, held in the cancel stop button but nothing seems to solve it.
thanks
turn machine off select 90 deg cotton press and hold start, switch on keep holding start for three secs it will then flash
turn knob to spin press start light codes as follows
prewash .................................. NTC
main wash ................................no heat
prewash and main wash.............. constant heat
rinse......................................... no fill
prewash and rinse ......................no drain
prewash main wash and rinse....... pressure switch
main wash and rinse ................... tacho/ pcb
rinse and cond ............................ no motor action
