My Beko WMA665W will fill with water then sit there flashing the rinse light? Any ideas what is wrong? Haven't had a chance to take it apart assume it might be pressure switch or heater? If I reset & select drain the drum will spin as it drains so assume motor is OK. If I select rinse by itself I get the rinse light fault again.
Any help would be appreciated.
