Hi There!!
Recently changed out the filter pump as the machine wasn't draining, worked successfully for about a week but has now failed again.
Drains ok but when I select any program the filter pump whirrs for about 5 seconds and then the whole program freezes and nothing happens. I turn off the washing machine and back on and try any other program and same result.
If I put it into test mode it just fills up non stop with water and I have to drain it bit by bit by selecting drain program and allowing it to drain for 5 seconds then reseting the program and draining for a further 5 seconds and so it goes
Any suggestions on what could be faulty??
