I have a eurosec CP8L system and two vortex bell boxes which I'd like to fit to the front and back of my house. I have configured the bell boxes so they are only triggered externally (the bell box tamper switch won't trigger the bell box directly). This should allow me to silence the alarm if there is a fault with the bell box tamper switch.
So far I can see the control panel and bell box wire together as follows:
SAB TMP TO Return
Bell Hold- TO Hold-
Bell- TO TG-
Bell+ TO Hold+
Strobe- TO STB-
Strobe+ (Unused)
I am planning to connect the two bell boxes in parallel, which I think should work except for the "SAB TMP to Return" connection. Is there a way of wiring the return from each bell box to the control panel such that tampering with either of the bell boxes will cause a tamper alert at the control panel (without directly triggering either bell box)? The control panel can then trigger both bell boxes if the system is armed.
If I connect the bell box return signals in parallel then both bell boxes would have to be tampered with before the the control panel was signalled. I could rewire the tamper switches in series, but I wondered if there was a standard solution. Thanks in advance.[/code]
SAB TMP TO Return
Bell Hold- TO Hold-
Bell- TO TG-
Bell+ TO Hold+
Strobe- TO STB-
Strobe+ (Unused)
