I have a Belling G707 Gas Cooker with a temperamental grill
Recently, we have found the grill difficult to light - typically ignites on one side only (left when facing oven). If we attempt to re-light then the grill will go out as soon as the handle is released.
Assuming it lights fully, then the grill seems to only operate at low heat.
I have Googled the problem and read suggestions that it may be a temperature switch/thermocouple - does this seem a likely suspect to the experts? If there is anything I should/can test then let me know.
The cooker is approx. 10 years old but remains in great condition. We'd ideally want to get it fix but would appreciate your advice as to whether this should be a cheap fix or not.
Thanks in advance.
Thanks in advance.
