I work for a charity and we are currently looking to improve the efficiency of our Ideal Concord CX240 boiler to redice our LPG bills down from around £10k.
At present, there is a Danfoss BEM 4000 unit installed, but over the years, the stats have become damaged and not replaced. As such, the BEM unit has been bypassed and is only used to turn the boiler on/off when there is a demand for heat. I also understand that the boiler is running on its internal stat which is inefficient and causes expensive dry cycling of the boiler??
We have been advised that the BEM unit uses a very crude method of controlling the boiler and applying its weather compensation, and we would be better fitting a more modern boiler management system to just control the burners and stop any dry cycling. One such example of this is is a vector boiler management system.
http://www.vectorgroupuk.com/solutions.html
To reinstate the BEM unit would only cost £51 but it is unclear on how effective this would be at saving money when compared to the Vector unit which doesn't have the weather compensation and costs £1600.
For some back ground info the heating is split into 3 zones with a 4th zone for HW. Each zone is controlled by its own time clcock and also has 30/60/90 min boost switches to allow our guests to call for heat outside the normal time slots. Each of the time clocks/boost switches send a signal to the BEM 4000 for heat and also opens the require motorised zone valves. Each radiator is fitted with TRV's and there are no room stats.
I am keen to get some opions on how best to proceed with this as all we seem to be getting is companies pushing their own devices and not what is in our best interest.
Is it best to stick with the BEM 4000 or replace it with a more modern device?
How efficient is the BEM 4000 going to be when compared to more modern devices?
How good is the BEM 4000 at stopping the Dry Cycling??
Does anyone have any recomendations on possible replacement which would fit into our current setup easily?
Does the weather compensation side of things really work?
Thanks in advance for your responses
Andy
Andy
