bending 15mm coated copper
30 Oct 2014
Blackpool
Can 15mm rigid coated coper be bent? I guess you can only bend it with a internal spring and not a pipe bender as the guids wouldn't fit
Yes you'd need a spring. Alternatively, normal copper and some heat shrink tube will achieve the same effect. Bend first, then apply heat shrink
