Bending square section steel tube
10 Dec 2008
Jersey Marine
Time for another project ... need to put a 90 degree bend in some 1.25" square section tube.
Not bought the section yet but guessing something like 16 gauge (0.064") or maybe I will need 14 gauge (0.08")
Obviously the bend radius will mean a reasonably gentle bend.
I have 2 questions if anybody has experience of such things.
# What is the minimum bend radius, I'll make sure I keep above this.
# Is this a practical bend to do at home ... or should I go to a fabricator and buy it 'bent'
If you are interested the project is:
http://www.eharder.com/Nova II/Trailer/Guide-on.html
(Not mine, just following somebody elses work.)
you'll bend round tube much easier.. 25mm steel conduit would do you.. the rollers would roll round it easier too :)
With the correct tools, It's much easier to bend square tube, as round tube has a greater radial strength.
For square tube you will need a specially shaped former to collapse the inner face uniformly.
You can see what happens to square tube when bent, in the pictures in your link.
With 1.25"sq. x 16 swg ERW, your centerline radius will be approx. 150 m/m
Find a local tube bender if you need smooth uniform bends, bending without the correct tools will crush the tube.
He will also tell you the radius he can bend.
yes but a 25mm conduit bender will be much ore readily available than a 1.25" square section bende.. and as it's for putting plastic pipe on as "rollers" I thought that round tube might be a better option..
Fair point, but looking further at the application, square tube for the bottom half, lends itself better for the final fitting onto the trailer.
Giving it further thought, I would not bend the tube, but I would weld a 90 degree joint instead and strengthen the corner with a welded gusset plate.
Much stronger than a bent tube.
