I'm planning to make a frame out of steel tube.
The lightest steel I can find is 12mm OD, 18swg / 1.2mm wall thickness.
For corners I am hoping to bend the pipe into right angles, without collapsing the tube.
Is this likely to be possible with a spring type pipe bender with this sort of pipe (with or without heat)?
Also what is the smallest radius I could hope for on the bends?
