Hi All
I have got a Bendix BIW 103W washing machine which won't start the high speed spin. I have checked the filter, the pump is pumping out, I have tried it with the drum empty. It starts to attempt the spin, stops and reverses as if balancing load and repeats about 3 times and then ends. The pump appears to be pumping during the procedure. I have checked the brushes and all the pipework is clear. I am not sure if there is an imbalance sensor and if so where to look. Any suggestions appreciated
Thanks chrisdur
Thanks chrisdur
