Hi all,
I'm in the process of having a new boiler installed after a disastrous 12 years with Baxi 105Ei. To compound the misery I've had to rip out all the old CH piping because I used the no barrier Hep2o which literally corroded my system.
I've re-piped everything, put new radiators in, and just need to choose a suitable boiler. Obviously there is a myriad of choice, but I've been pointed towards a Main 30kw. I've not heard of these before but apparently they are a pretty good valve reliable boiler. My flow rate is 13 lt/min so I want something that has a good hot water output, and can heat 11 rads.
I'd say my budget is approx £1400 for the boiler and associated bits i.e flue RF timer, magna clean, pipe, fittings etc
I'd really appreciate any advice.
Cheers
Cheers
