Best Backing plaster
16 Nov 2006
About to plaster the kitchen. Have taken the tiles of all the walls and as usual the existing plaster has broken off exposing the brick in many places. Think I will chip it all off and start over, unless advised otherise
Whats the best backing plaster to use Browning, Hard wall etc.
don't want it going off to quickely before its flat, Im just an amateur?
Thanks for any advise
browning is, in my opinion the easiest to use.
you can prolong the working time of the plaster by applying a scratch coat first then a top coat a little later.
the scratch coat will deal with the initial suction of the wall freeing up more time for ruling off and floating on the face coat. don't leave it too long between coats. same day applications are quite normal.
