Extension walls going up nicely. The ground floor is brick face and the second floor will be rendered. There is also a parapet wall to be made of block and rendered on the first floor of the extension.
The builders have asked which type of blocks I will use - the SE calcs simply show 4N blocks. I have read elsewhere here that lightweight blocks don't render as well. I guess the inner skin should be lightweight blocks
On a slightly different note, which blocks should I use for internal loadbearing walls and blocking up windows?
Thanks as always,
Matt
Thanks as always,
Matt
