Best direct electric water heaters
9 Dec 2017
I am considering replacing my broken Elson Coral E direct electric water heater. What would be the best alternative I should look at? I have seen options here: https://www.advancedwater.co.uk/group-088.html but it is hard to understand why prices vary from £500 - £1800 for same capacity water filter.
My criteria are:
1) Electric water heater
2) Double immersion element
3) 150l capacity
4) Support offpeak mode
5) Includes insulation
Optional:
Rectangular shape
What brands and models would you recommend to look at?
Thanks a lot
Sergejs
I'd have a word with Newark Copper Cylinders - <http://www.newarkcoppercylinder.co.uk/>. They'll make what you want and may well be familiar with the old one you are replacing. Things that I would consider first:
1) Electricity is the most expensive and carbon inefficient form of heating. Better off with mains gas or heat pump.
2) Direct vented systems are pretty out of date. Bottom of tank ideal for harbouring sludge and legionella. Instantaneous heaters and combi boilers are safer.
3) If you are using economy 7, you'll need a time clock for your heater. Make sure the heater clock syncs up with the clock on the electricity meter, sometimes these can be many hours slow or fast.
Don't know why some should be more expensive. Added gizmo's and just getting what they can. Unvented cylinders need to take more pressure and that can add to the cost. Some may claim to be more efficient. Electric immersion heaters with are all exactly 100% efficient but good insulation will allow you to keep more of that 100%.
Good luck.
A direct unvented cylinder could be considered,ok it will need extra plumbing to install.
